ASA 5100 error in VPN
Oct 23rd, 2008
It works some time .. and some time it doesn't work properly and prompt me this error upon log in to SSL VPN Portal.
the erorr is "Unable to update the session management database."
Can someone advise ?
ajagadee Fri, 10/24/2008 - 07:48
  • Cisco Employee,
Jason,
Do you have a Cisco Username/Password? With proper Cisco Login Credentials, you should be able to look up the Bug ID using the URL that I had posted earlier.
The issue that you describe closely matches the bug id. What version are you running on the ASA? The bug is fixed in 8.0(3) and higher. Is upgrading the ASA an option?
Arul
*Pls rate if it helps*
