router reboots
Oct 23rd, 2008
Dear sir,
i have a isdn bri backup line for my leased line,
to check whether the backup is working or not, I removed the backup bri isdn from the router and for a few minutes the bri is working after the router gets hanging, then automatically reboots,
it shows error.
IOS (tm) C1700 Software (C1700-Y-M), Version 12.1(27b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 16-Aug-05 18:22 by pwade
Image text-base: 0x80008088, data-base: 0x8060B4F8
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
082CH.1.BR uptime is 0 minutes
System returned to ROM by error - a SegV exception, PC 0x8014E0FC
System image file is "flash:c1700-y-mz.121-27b.bin"
cisco 1750 (MPC860) processor (revision 0x601) with 12288K/4096K bytes of memory
Processor board ID JAD04400ONI (3667262116), with hardware revision 3097
M860 processor: part number 0, mask 32
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial(sync/async) network interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
4096K bytes of processor board System flash (Read/Write)
Overall Rating: 3 (2 ratings)
satish_zanjurne Fri, 10/24/2008 - 06:33
Could not find any reference of software bug.
But if you have spare Cisco 1700 with same IOS, then try to test your BRI on it, without much config.
HTH..rate if helpful..
Richard Burts Sat, 10/25/2008 - 11:00
Prem
The error message about:"System returned to ROM by error - a SegV exception, PC 0x8014E0FC" is almost certainly a software error. And the 12.1(27b) code that you are running is pretty old and there have been several vulnerabilities identified to which it might be affected. The best advice is to upgrade the IOS to a more recent version.
Rick
