LMS 3.1 License Limit .
Oct 23rd, 2008
Hi ,
We upgrded LMS 3.0 to 3.1. Now LMS 3.1 shows license for 300 no of devices only . What is the maximum number of devices can be supported by the LMS 3.1 by default .
In order to increase the number devices which license should I get ?
Regards ,
Sinjish.K
Joe Clarke Fri, 10/24/2008 - 11:29
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The highest single license you can purchase is for 10,000 devices. However, you will have to deploy multiple LMS servers to fully support that device count. Each license allows for a 10% overage. So with a 300 device license, you'll be able to manage 330 devices, but you will be nagged if you go over 300. If you exceed 330, LMS applications will not manage any additional devices.
