Using templates in BAT
Oct 24th, 2008
Does anyone has the procedure to create and apply the templates in BAT?
mikram Fri, 10/24/2008 - 01:32
Did you look at BAT configuration guide. It has everything you do need to know about BAT. Which version of CUCM you are using?
Here is link to CUCM 5.2.1 Guide
https://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/5_2_1/5_2_1.html
If you are using CUCM 6.0, here is the link to BAT Guide
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/6_0_1/bat-wrapper.html
Hope this helps.
Cheers
Ikram
