Clientless SSL VPN Certificate error
Oct 24th, 2008
i have recently configured Clientless SSL VPN in 5505 when i try to connect the FW Outside interface if (i,e, https://216.X.X.X) it throws an warning as
The security certificate presented by this website was not issued by a trusted certificate authority.
Security certificate problems may indicate an attempt to fool you or intercept any data you send to the server.
jason_nah Fri, 10/24/2008 - 02:21
How abt obtain a valid Cert from Verisign or free website like Starcom ?
gandhi.ganesh Fri, 10/24/2008 - 02:39
Fine, what i need to to get that,
& will this certifcate be valid to my webserver which is there in DMZ
gandhi.ganesh Fri, 10/24/2008 - 10:14
I have installed the certificate in my pc, its fine now i am not the getting any error.
few questions:
1. is this certificate is safe, because we are going to use this to connect our webserver which is behind the FW
2. In how many pc's i can install this certificate.
jason_nah Sat, 10/25/2008 - 06:14
1. Shold be safe. Since some guys from TechPro recommend it.
2. So far I didn't come across a limitation to install the cert.
gandhi.ganesh Wed, 10/29/2008 - 22:20
Can i import this certificate to FW? if yes how ?
because i can't install manually these certificates to all pc's of my client who are sitting around the world.
mu requirements is when we try to access https://216.x.x.x the fw should export the certificate file to client pcs
Waiting for the quick reply
