Reflexive Access Lists
Oct 24th, 2008
Hi Gurus,
My Reflexive Access Lists is not woking, do you have any idea on it ? am i did the wrong config ?
* i juz wan my telnet session reflect in the ACL.
ip access-list extended OUTR2
permit tcp any any eq telnet reflect test
deny ip any any
ip access-list extended INR2
evaluate test
deny ip any any
interface Ethernet0/0
ip access-group INR2 in
ip access-group OUTR2 out
Giuseppe Larosa Fri, 10/24/2008 - 05:02
  • Hall of Fame,
    Founding Member
Hello William,
the first thing to do is deciding if your scenario requires configuration on an internal interface (internal LAN) or external interface.
In the case of internal interface that could fit in your case:
Internal Interface Configuration Task List
To configure reflexive access lists for an internal interface, perform the following tasks:
1. Defining the reflexive access list(s) in an inbound IP extended named access list
2. Nesting the reflexive access list(s) in an outbound IP extended named access list
3. Setting a global timeout value
see
http://www.cisco.com/en/US/docs/ios/security/configuration/guide/sec_cfg_ip_filter_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1001063
So probably you should try the opposite of what you have done
Hope to help
Giuseppe
