drolemc Sun, 11/02/2008 - 17:15
  • Silver, 250 points or more
Switch to the handset from the desktop charger speakerphone
1. Hold the top of the phone and move it forward before lifting it off the desktop charger.
2. Use the handset to continue with the call. The desktop charger speaker and microphone disconnect. Else
You try setting the following Telephony-Service options to disable the "speaker mode" but it only disables the button.
service phone disableSpeakerAndHeadset true
service phone disableSpeaker true
tim.giles Mon, 11/03/2008 - 07:22
Hi, there's also a couple of similar bugs relating to 7921's with CME. Are you using CME or full CCM?
Details on one of the bugs below:
CSCsj20985 Bug Details
7921 enters speakerphone mode after call park retrieval with CME
Symptom: 7921 enters speakerphone mode after call park retrieval with CME.
Condition: 7921 retrieving a call that is parked using CME.
Workaround: Press speakerphone button to return to handset mode
davieshuw Mon, 11/03/2008 - 12:23
Its CME. how amusing is it that cisco's work around is to press the speakerphone button!
