call manager 5 services all failed
mikram Fri, 10/24/2008 - 05:38
Is this new server installation or it used to work before and stopped working?
Do you have enough node license installed? What does it says when you check License unit report.
Jaime Valencia Fri, 10/24/2008 - 06:00
if you can log via ssh i'd recommend a reboot from that SUB
if this helps, please rate
Jaime Valencia Fri, 10/24/2008 - 06:10
ok, log thru ssh
what's the status of the services?
keithknowles Sun, 11/09/2008 - 13:35
Any luck on this? I am seeing the same issue on a Publisher.
Hi after several reboots to no avail the sub was left due to the weekend and surprisingly came back to life. Which was lucky as we also had a hardware failure on the pub. The sub has now been up on line for over a week with no hitches. How long has the pub been up as i heard of an issue were ccm sevice may failure after 248 days ??
keithknowles Mon, 11/10/2008 - 09:34
Yeah I heard about the 248 day bug too but ours had been restarted just a week prior to the failure, our problem was actually related to a Database Lock identified in bug CSCsr91282.
