ASA capture from a context
Answered Question
Oct 24th, 2008
I have a ASA set up with two context for active active failover. Before this configuration I use to do packet capture on the ASA and transfer them to my computer with the following command:
copy /pcap capture:inside tftp:
Since the context configuration I have not been able to do this. If you are in a non system context you do not get the \pcap or capture options. If I am in the system context, I get the \pcap or the capture options, but this does not work.
Does anyone have a work around for this?
Correct Answer by ajagadee about 8 years 5 months ago
Gary,
Use the below format:
copy [/noconfirm] [/pcap] capture: [context_name/]buffer_name url
Arul
*Pls rate if it helps*
Overall Rating: 5 (1 ratings)
Correct Answer
ajagadee Fri, 10/24/2008 - 06:38
  • Cisco Employee,
Gary,
Arul
gm-douglas Fri, 10/24/2008 - 07:38
Putting in the name of the context was the trick. Works perfect.
