7941 problems with bulk-speed-dial
We just upgrade de 7941 firmware from SCCP41.8-2-2SR1S to SCCP41.8-4-1SR1S.
Now we have a problem. From those phones, they can not use de bulk-speed-dial. These only happens since the firmware upgrade.
The CCME version is 4.1(0).
I have the bulk-speed-dial in telephony service. All the other phones can use the bulk speed dial. With the earlier firmware version, 7941 phones work just fine.
Any ideas ??
owillins Fri, 10/31/2008 - 08:21
  • Silver, 250 points or more
1. Can you verify or if not do the following
- no create cnf / create cnf under telephony-service and reloaded the phones
2. You have the correct format for your bulk speed dial list.
You have these fields: prefix to dial; actual number wanting to dial; description; and then these two last fields are optional append and hide. Verify your configuration Use this command
show telephony-service bulk-speed-dial
