uninstall exchange server
Oct 24th, 2008
If exchange application on one of the servers is uninstalled(not the partner server, but it had subscribers before, now all the subsribers are moved to other servers), do we have to do anything on the messagestore wizard? The reason I am asking this is that I know we had to check the checkbox for all the exchange servers where there are subscribers. I am assuming this exchange server should automatically disappear from the messagestore wizard, right?
Brandon Buffin Fri, 10/24/2008 - 07:02
I would recommend running the MSCW after removing the server. It wouldn't hurt anything and would ensure that references to the other server are removed.
Brandon
Bradford Magnani Fri, 10/24/2008 - 07:07
If you move users to new servers, make sure that you re-run Permissions Wizard and include the new Exchange servers/mail stores.
Brad
ciscoforum Fri, 10/24/2008 - 07:12
The servers where subscribers moved to are actually exisiting servers. They have 5 server, now down to 4.
Bradford Magnani Fri, 10/24/2008 - 07:17
If Permissions Wizard has been run for the new servers already, what Brandon mentioned wouldn't be a bad idea. Point MSCW to your currently partnered Exchange server and let it do its directory sync.
Brad
ranpierce Fri, 10/24/2008 - 07:20
Only adding servers you need to rerun the PW and if you are partnering with a different exchange server MSCW.
Has long as the mailstores that you moved the users too was in the list the first time. you are fine.
PW will only give rights not take away.
Randy
