PoE stats via SNMP
Oct 24th, 2008
How can I retrieve PoE info from a Cisco switch using SNMP?
sdavids5670 Tue, 10/28/2008 - 07:53
To answer the first question, the software version is IOS 12.2(25) SEE2. Switch model is 3560.
As for the CISCO-POE-PD-MIB, I've tried walking that tree and I get nothing back from the switch. SNMP is enabled on the switch and I'm getting info back from queries, just not from 1.3.6.1.4.1.9.9.414.
Joe Clarke Tue, 10/28/2008 - 08:23
There is no PoE SNMP support in the image you are running. If you upgrade to 12.2(35)SE, you will have support for the POWER-ETHERNET-MIB and the CISCO-POWER-ETHERNET-EXT-MIB.
sdavids5670 Mon, 03/23/2009 - 08:22
The origin of this question is that I have a client who is currently using Cisco Network Assistant to look at statistics for PoE Utilization. I'm wondering why he can see PoE Utilization via Cisco Network Assistant but I cannot see anything using SNMP on OIDs in POWER-ETHERNET-MIB and CISCO-POWER-ETHERNET-EXT-MIB. Does Cisco Network Assistant use something other than SNMP to glean this information?
Joe Clarke Mon, 03/23/2009 - 09:27
Cisco Network Assistant does not use SNMP. It simply executes CLI commands on the device, and parses those.
