To many input CRC error on T1 int.
I am getting too many errors(just in 20 minutes) on S0/0 int. The user is complaining of slow connection.. What is the problem?
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
reliability 234/255, txload 3/255, rxload 58/255
Encapsulation FRAME-RELAY IETF, loopback not set
Keepalive set (10 sec)
LMI enq sent 380, LMI stat recvd 377, LMI upd recvd 0, DTE LMI up
LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0
LMI DLCI 0 LMI type is ANSI Annex D frame relay DTE
Broadcast queue 0/64, broadcasts sent/dropped 0/0, interface broadcasts 0
Last input 00:00:03, output 00:00:00, output hang never
Last clearing of "show interface" counters 01:03:24
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 353000 bits/sec, 36 packets/sec
5 minute output rate 24000 bits/sec, 20 packets/sec
148534 packets input, 173672761 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
19484 input errors, 11414 CRC, 5780 frame, 0 overrun, 0 ignored, 2290 abort
94188 packets output, 21767985 bytes, 0 underruns
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Overall Rating: 5 (2 ratings)
allan.thomas Fri, 10/24/2008 - 09:17
  • Blue, 1500 points or more
The output indicates that the reliability is not 100% healthy (234/255), this suggests that you possibly have a physical issue or clocking issue between the CE and the NTU.
Ordinarily the reliability should be 255/255, the fact that it is not will undoubtedly contribute the input errors and CRC that you are experiencing.
Either report the fault to your carrier/telco, or initially try replacing the cable.
Allan.
Giuseppe Larosa Fri, 10/24/2008 - 09:19
  • Hall of Fame,
    Founding Member
Hello Manjinder,
there is clocking or cabling problem
First of all, have someone resets the external CSU on both ends of the link.
If this doesn't slove Contact the WAN provider and have them perform the classic loopback tests
Hope to help
Giuseppe
bagvanliju Fri, 10/24/2008 - 11:06
Hai,
Try to take a local loop from modem that will confirm router interface,V.53 cable.If this is clean ask TElco to provide loop
from next node (Mux RSU).(before this reset the modem/CSU/Dsu ..clear the counters and see reliablity is comming to 255/255 also check wheather the errors are increasing rapidly ....
in this case as Allan,Giuseppe mentioned seems to be L1 issue.
(19484 input errors, 11414 CRC,)
ujil
sdoremus33 Mon, 11/03/2008 - 12:37
  • Bronze, 100 points or more
You can check to see what the keealive variable is on the other end of the connection
Keepalive set (10 sec) at local device,sometimes uncorrect keepalives at both ends can cause this issue.
Keealive local =10
Keepalve remote= 10
johnlloyd_13 Mon, 11/03/2008 - 13:53
hi,
i just had a similar problem not too long ago. try show controllers t1 and specifically look at 'slip' errors that are incrementing on each interval. we've done looptest with telco and they corrected the problem with clock config on their side. you should press them for checking their configurations.
my t1 before:
T1 0/1/1 is up. (Line Looped (inband CSU code)) (Line Loop by Remote)
Applique type is Channelized T1
Cablelength is long gain36 0db
Description: "Slot 1 Port 1 VWIC2-2MFT T1 Card"
Receiver has no alarms.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20071011, FPGA: 13, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (714 seconds elapsed):
0 Line Code Violations, 1182 Path Code Violations
715 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 11 Degraded Mins
715 Errored Secs, 350 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
t1 after clock was corrected at provider:
T1 0/1/0 is up.
Description: "Slot 1 Port 0 VWIC2-2MFT T1 Card"
No alarms detected.
Data in current interval (477 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 1:
Data in Interval 2:
