CSA (okclient.exe not running)
Oct 24th, 2008
On 2 of my hosts, the CSA Flag is not running. I uninstalled and reinstalled durning setup the flag was visible. As soon as it finished it closed. The okclient is not running. Any ideas?
tsteger1 Fri, 10/24/2008 - 11:05
  • Red, 2250 points or more
First try running it from the application folder to see if it works.
Installation creates a shortcut for Okclient in the All Users startup folder.
If that doesn't work, check to see if the host has the Agent UI Module applied.
If it doesn't or if Allow user interaction is unchecked, you won't see the flag.
Tom
tsmithpnb Fri, 10/24/2008 - 12:00
Tried running it but nothing comes up. Agent UI is applied and checked.
tsteger1 Fri, 10/24/2008 - 13:01
That's the only reason I've not seen it show up.
Tom
