allan.thomas Fri, 10/24/2008 - 11:34
  • Blue, 1500 points or more
What version of firmware is running on the 7985? The reason I ask is that I came across this bug which you maybe running into?
It states the IP Phone ignores CDP. When CDP is enabled on the switchport, the phone is not detecting CDP?
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsf11074
Firstly is CDP enabled on the switchport? Secondly have you tried resetting the Phone?
Allan.
praveenalampall... Tue, 10/28/2008 - 13:29
i did reset the phone and enabled cdp on the switch port.
firmware version on the phone is CMTERM_7985.4-1-4-0.
thanks for replying
Praveen
