ACS 4.2 Cert Generation and install
Answered Question
Oct 24th, 2008
I am trying to genartate a self signed cert and send it to a FTP server. then i am try to install it. But i can never get it to send the files to the FTp server. I have gone over the document, but can't get it to work.
mike
Correct Answer by Jagdeep Gambhir about 8 years 2 months ago
Mike,
It seems you wants to install SSCert on same acs. If that is the case then there is no need to FTP it. Simply check install certificate option (leave ftp section blank) and submit.
Cert is installed.
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
Correct Answer
Jagdeep Gambhir Fri, 10/24/2008 - 16:37
Mike,
Cert is installed.
~JG
