10-24-2008 11:28 AM - edited 03-11-2019 07:02 AM
I want to create another transparent security context in the my company's FWSM.
There are already several other security contexts created: 4 - routed & 1 - transparent
recently, we re-partitioned from the default 12 memory partitions to 5 memory partitions
I just want to create a new transparent security context ... that shouldn't require a FWSM reload, should it?
thanks,
Solved! Go to Solution.
10-24-2008 11:40 AM
Kevin
Creating a new context does not require a reload but be aware that if you have only 5 memory partitions created and all 5 have been allocated a context then your new context will have to share a memory context with an existing partition.
Jon
10-24-2008 11:48 AM
Hello Kevin,
There is no need to reload the FWSM when you create the context in multiple context mode.
Arul
*Pls rate if it helps*
10-24-2008 11:40 AM
Kevin
Jon
10-24-2008 11:49 AM
true, two of the larger ACL'ed contexts have their own memory partition, and the remaining are smaller ones will be sharing memory partitions
cool, thanks
10-24-2008 11:48 AM
Hello Kevin,
Arul
