LMS 3.1 DFM trap forwarding to CM
Oct 24th, 2008
Run into a bit of a problem while configuring this dynamic user tracking feature: the switches send MC-notification traps to DFM, the DFM is set to forward ALL traps to CM via
FORWARD: *.*.*.* .* * * localhost:1431:xxxx
CM seems like getting something but cannot decode (the CM does not validate either the community of the traps or the source of the traps, DFm and CM are on the same box).
The DEBUG of for the user tracking is set for MAC UHIC and this is what I get:
2008/10/24 15:45:00 Thread-11 macuhic DEBUG SocketListener: Packets received: 4722
class com.cisco.nm.cm.ut.uhic.mac.AsnDecoder.AsnObject: CB-Error-wrongstatus.v2: Skt IP Address: 127.0.0.1, Wrong Status: 1, Version: AsnMakeMe_snmp_v2c: SNMPv2c
2008/10/24 15:45:00 pool-1-thread-2 macuhic DEBUG Decoder: SnmpPdudeviceIP : 127.0.0.1 timeStamp : 0 Processed : false
Decoder Stage: deviceIP : 127.0.0.1 timeStamp : 0 Processed : false
Has anyone dealt with this issue before?
Joe Clarke Fri, 10/24/2008 - 11:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Have you enabled the reception of forwarded traps in Campus? If so, it looks like there is an ASN.1 decoding error. SNMPv2c traps are supported, so this should really work provided DFM trap listening is enabled in User Tracking.
Note: Dynamic UT only process the MAC change traps, and not the MAC move traps.
dmitry Fri, 10/24/2008 - 12:23
Thanks for your reply, just tried switching to SNMP v1 and it works now (looks like SNMP v2 traps are broken either in the DFM forwarding or CM trap receiver):
2008/10/24 15:54:00 pool-1-thread-3 macuhic DEBUG Decoder: SnmpPdudeviceIP : 10.224.102.3 timeStamp : 2040990409 Processed : true
Decoder Stage: deviceIP : 10.224.102.3 timeStamp : 2040990409 Processed : true
2008/10/24 15:54:00 pool-1-thread-3 macuhic INFO TrapListenerFilterImpl: TrapListenerFilterImpl.valid()
2008/10/24 15:54:00 pool-1-thread-4 macuhic INFO TrapListenerFilterImpl: TrapListenerFilterImpl.valid()
2008/10/24 15:54:00 pool-1-thread-4 macuhic INFO MacUhicDBTransaction: Received Mac Event Size: 1
2008/10/24 15:54:00 pool-1-thread-3 macuhic INFO MacUhicDBTransaction: Received Mac Event Size: 1
2008/10/24 15:54:00 pool-1-thread-4 macuhic INFO MacUhicDBTransaction: Entered queueEntries
2008/10/24 15:54:00 pool-1-thread-3 macuhic INFO MacUhicDBTransaction: Entered queueEntries
2008/10/24 15:54:00 pool-1-thread-3 macuhic DEBUG MacUhicDBTransaction: Adding00-19-30-d5-35-cd to the HashedQueue
2008/10/24 15:54:00 pool-1-thread-4 macuhic DEBUG MacUhicDBTransaction: Adding00-17-0e-7d-f9-1d to the HashedQueue
2008/10/24 15:54:00 pool-1-thread-4 macuhic INFO MacUhicDBTransaction: Returning after queuing the MacUhicEntry
2008/10/24 15:54:00 pool-1-thread-3 macuhic INFO MacUhicDBTransaction: Returning after queuing the MacUhicEntry
2008/10/24 15:54:01 Thread-10 macuhic DEBUG MacUhicDBTransaction: Adding to the Array List for processing to DB
2008/10/24 15:54:01 Thread-10 macuhic INFO DBConnectionThread: Starting new non-dup Database updationThread[Thread-10,5,main]
2008/10/24 15:54:01 Thread-10 macuhic INFO DBConnectionThread: Calling the Duplicate Mac procedureThread[Thread-10,5,main]
2008/10/24 15:54:01 Thread-10 macuhic INFO DBConnectionThread: Calling the duplicate Mac00-17-0e-7d-f9-1dThread :Thread[Thread-10,5,main]
2008/10/24 15:54:01 Thread-10 macuhic INFO DBConnectionThread: Event : Event type: 1 Device ip: 10.224.102.3 dot1dbaseport: 48 VLANId: 20 TimeStamp: 1224878040924 PortName :Fa0/44DomainName :OTN-TORONTOVlanName :OTN-DATAVlanType :ethernetPort Desc :Port Duplex :unknown-duplexPort Speed :100MPort State :staticDevice Name :torotnswi0099b
2008/10/24 15:54:01 Thread-10 macuhic INFO : DBConnectionThread: DB update - InActive->Active Record - sucess : 00-17-0e-7d-f9-1d1
2008/10/24 15:54:01 Thread-10 macuhic INFO DBConnectionThread: Exiting out of the Duplicate MAc procedure call MAC:00-17-0e-7d-f9-1dThread :Thread[Thread-10,5,main]
2008/10/24 15:54:01 Thread-10 macuhic INFO DBConnectionThread: Removed MAC:00-17-0e-7d-f9-1d from the queue Thread:Thread[Thread-10,5,main]
Joe Clarke Fri, 10/24/2008 - 18:00
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I've only used SNMPv1 myself, but the documentation states SNMPv2 notifications are supported. Can you try configuring one switch to send v2 traps directly to the CM server, and see if that works?
