WAAS,, NO CME, Not Peering
Oct 24th, 2008
Hi, I've got two WAEs in the lab, running without a CME, as Edge accelerators, connected to 3560s with WCCP. Going through all the docs and playing with it, I get the following results:
1) WCCP is up and enabled
2) Matching flows are seen on both WAEs
3) Each sees the other as a peer in "show stat tfo peer"
4) "show tfo connection sum" while FTPing shows failure of peering:
WAAS1#show stat tfo peer
Peer Id: 00:1a:64:f2:05:d1
Orig Bytes Read: 106746709
Orig Reads: 5414
Opt Bytes Reads: 117170
Opt Reads: 3197
Orig Bytes Written: 0
Orig Writes: 0
Opt Bytes Written: 40873679
Opt Writes: 7838
Number Encodes: 9645
Number Decodes: 7715
Active Connections: 0
Total Connections: 24
Last contact time: Wed Oct 22 14:36:53 2008
WAAS1#show tfo connection sum
Pass-Through Connections
Local-IP:Port Remote-IP:Port Conn Type
172.33.200.2:1524 192.168.250.42:21 PT App Cfg
192.168.250.42:20 172.33.200.2:1529 PT No Peer
192.168.250.42:21 172.33.200.2:1524 PT App Cfg
172.33.200.2:1528 192.168.250.42:20 PT No Peer
172.33.200.2:1529 192.168.250.42:20 PT No Peer
192.168.250.42:20 172.33.200.2:1528 PT No Peer
Orig Reads: 5414
Opt Reads: 3197
Orig Writes: 0
Opt Writes: 7838
ngods Mon, 10/27/2008 - 16:39
No hints? What about using GRE instead of l2-redirect?
Zach Seils Wed, 10/29/2008 - 03:15
The 3560 WCCP implementation does not support GRE forwarding/return.
The 'PT No Peer' reason shown in your original output indicates that the WAEs do not see each other. The output you provided is from the same WAE (WAAS1). Can you provide the output from both WAEs?
Zach
