Need Help ASAP. PoE Question
Oct 24th, 2008
  • Blue, 1500 points or more
Got a 3750 running 12.1(19)EA1d
I get into the interface, execute the power inline auto command, but when I do a show power inline, it says its turned off...
Is there a global config command for PoE?
Does this 3750-24p switch running this code support PoE?
george.psaras Fri, 10/24/2008 - 13:27
Does your switch support POE? There are some 3750's without POE.
lamav Fri, 10/24/2008 - 13:41
This one should...when I do the show power inline command, it gives me an output instead of just saying that the switch doesnt support it.
