DSP Resources
CHRIS CHARLEBOIS Fri, 10/24/2008 - 13:31
  • Silver, 250 points or more
I beleive it is show dsp dsp idle, but that only shows how many are not in use.
Jaime Valencia Fri, 10/24/2008 - 14:11
  • Cisco Employee,
  • Hall of Fame,
    2011
you can issue sh voice dsp, it will show resources allocated and which are idle
java
if this helps, please rate
allan.thomas Fri, 10/24/2008 - 14:17
  • Blue, 1500 points or more
The command 'show voice dsp detailed' should give the detail that you require, it shows the voice dsp channels and the dsp each channel is assigned to.
Allan.
Pls rate helpful posts.
