Warning message
allan.thomas Fri, 10/24/2008 - 14:12
  • Blue, 1500 points or more
Open the CallManager service parameters and expand to list all advance parameters to be sure.
Locate the clusterwide parameters - (Service), here you can change the default audio source id for both Network and User.
Allan.
Pls rate helpful posts.
Jaime Valencia Fri, 10/24/2008 - 14:14
  • Cisco Employee,
  • Hall of Fame,
    2011
you mean the actual audio file??? or where to change the selection??
the selection is an enterprise parameter, then a device pool setting, then device and then line. they take precedence in the reverse order i put them
java
if this helps, please rate
allan.thomas Sat, 10/25/2008 - 05:29
Hi Paul, we're here to help if we can, hope we were able to provide you with the help that you needed?
All the best.
Allan.
Please rate helpful posts. Thanks.
