Invalid input trying to configure FWSM int
Answered Question
Oct 24th, 2008
Hello all,
I'm building a brand new FWSM running 3.2(2) and have already configured for failover and verified communications between the two. I have also put them both into mode multiple and created 3 contexts. I also assigned the vlan interfaces from the switch to each vlan group as needed. Finally, I went into the admin context and allocated the interfaces to the proper context.
The problem now is when I go to any context and type:
conf t
interface xyz
I get "invalid input" back. If I do interface ? it shows me the names of all my interfaces. If I do interface x and hit tab, it autocompletes the right name. But no matter what, i can't get into interface config mode. Any ideas?
Thanks in advance for the help!
Correct Answer by ajagadee about 8 years 5 months ago
Matt,
The bug is present in 3.2 and is fixed in 3.2.3 and higher. So, upgrading the FWSM to 3.2.3 or higher should fix the issue that you are running into.
Arul
*Pls rate if it helps*
Overall Rating: 4 (1 ratings)
ajagadee Fri, 10/24/2008 - 17:35
  • Cisco Employee,
Matt,
Can you post the outputs of the system context where you have assigned the interfaces for the specific context and also the exact outputs when you try to configure the command.
In the meantime, look at Bug ID CSCsk32932 which is a close match of the issue that you are experiencing.
http://www.cisco.com/en/US/docs/security/fwsm/fwsm31/release/notes/fwsmrn31.html
Arul
MATTHEW BECK Mon, 10/27/2008 - 06:24
Hi Arul,
It does sound similar but I'm running 3.2(2) and that bug was fixed back in 3.1x. Here's the show run I've put together so far.
FWSM/Prod/act(config)# sho run
: Saved
FWSM Version 3.2(2)
hostname Prod
names
interface tocore
no nameif
no security-level
no ip address
interface Infra
no nameif
no security-level
no ip address
interface OXI
no nameif
no security-level
no ip address
interface OXE
no nameif
no security-level
no ip address
interface OXWeb
no nameif
no security-level
no ip address
pager lines 24
logging buffer-size 16384
logging buffered informational
no asdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 1:00:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
telnet timeout 5
ssh timeout 5
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect skinny
inspect smtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
Cryptochecksum:xxx
: end
Thanks again for the help!
Matt
Correct Answer
ajagadee Mon, 10/27/2008 - 11:58
  • Cisco Employee,
Matt,
Arul
MATTHEW BECK Mon, 10/27/2008 - 13:11
Hello again,
Yeah, I opened a TAC case and they gave me a work-around so I could upgrade the code. I'm now running 3.2(8) and the problem doesn't occur.
FWIW, the work-around involved not providing an alias while allocating interfaces in the system context. For example, my original config said:
allocate-inter vlan50 tocore
This has the affect of hiding the VLAN tag from the context and just showing "tocore" as the interface. I took out that command and put it back in as:
After doing that, I could configure that interface in the context, get an IP on there and upgrade the image. Once I reloaded with the new image all my other aliases worked just fine because, as you mentioned, the problem was resolved in 3.2(3).
Thanks for your input and enjoy your week!
Matt
