10-24-2008 06:54 PM - edited 07-03-2021 04:41 PM
I was wondering, how do you upgrade the license on a AIR-WLC4402-25-K9 to handle 50 access points instead of 25? Is it simply just a software upgrade or license upgrade? And how do we purchase the upgrade software or license? What's the part number? I couldn't find it anywhere.
Solved! Go to Solution.
10-25-2008 06:14 AM
Hi Nolan,
You won't love this answer but, the number of supported AP's on a WLC is based on the Hardware configuration and cannot be changed. You will need to purchase a second WLC. The upside is you will be able to add some redundancy to your deployment :) Here is a clip;
\\The limitation on the number of supported access points is based on the hardware that you have. The 4402 WLC with two gigabit Ethernet ports comes in configurations that support 12, 25, and 50 access points. The 4404 WLC with four gigabit Ethernet ports supports 100 access points.
AIR-WLC4402-12-K9
4400 Series WLAN Controller for up to 12 Cisco access points
AIR-WLC4402-25-K9
4400 Series WLAN Controller for up to 25 Cisco access points
AIR-WLC4402-50-K9
4400 Series WLAN Controller for up to 50 Cisco access points
AIR-WLC4404-100-K9
4400 Series WLAN Controller for up to 100 Cisco access points
Hope this helps!
Rob
10-25-2008 06:14 AM
Hi Nolan,
AIR-WLC4402-12-K9
AIR-WLC4402-25-K9
AIR-WLC4402-50-K9
AIR-WLC4404-100-K9
Hope this helps!
Rob
10-28-2008 06:44 AM
Send your Cisco Partner a Purchase Order for a new 4402-50. LOL Unfortunately like Rob says, there is no upgrade. That may change in the future.
