10-24-2008 08:22 PM - edited 03-04-2019 12:04 AM
Dear sirs,
Its regarding the serial IP addresing.
sir,
is it possible to give the 2 ip address to a serial ?
if yes then please give the procedure.
with rtegards
sanju kumar
10-24-2008 08:34 PM
Hello Sanju,
interface Serial0/1
ip address 30.1.1.1 255.255.255.0 secondary
ip address 20.1.1.1 255.255.255.0
Arul
*Pls rate if it helps*
10-27-2008 02:04 AM
Dear Arul,
i tried this on 3600 series of router but it gives me the follwing error message" /24 is bad subnet mask"
the commands are :
router(config)#ip address 172.16.1.0 255.255.255.0
router(config)#ip address 172.16.2.0 255.255.255.0 secondary
/24 is bad subnet mask .
please give solution for the above.
with regards
sanju.
10-27-2008 03:04 AM
Sanju,
172.16.2.0 /24 is network id for this pool..
Try 172.16.2.1 /24 as secondary ip.
HTH !
