Multicast causing high CPU
Oct 24th, 2008
In my network we are facing high CPU causing because of multicast traffic...
The source of mylticast having 155.x.x.x and Group 239.x.x.x.
currently we have placed a access-list to stop causing high CPU as below but now concerned is that we are not able to get the multicast video from this source.
access-list 1 deny 239.0.0.0 0.255.255.255
When we take out the above acl so again it causing the high CPU.. I have checked the and found the RPF failure as below,
ds1#sh ip mroute 239.x.x.x count
IP Multicast Statistics
102 routes using 77310 bytes of memory
29 groups, 2.51 average sources per group
Forwarding Counts: Pkt Count/Pkts per second/Avg Pkt Size/Kilobits per second
Other counts: Total/RPF failed/Other drops(OIF-null, rate-limit etc)
Group: 239.x.x.x, Source count: 1, Packets forwarded: 0, Packets received: 467885775
RP-tree: Forwarding: 0/0/0/0, Other: 0/0/0
Source: 155.x.x.x/32, Forwarding: 0/-92/0/0, Other: 467885775/20990877/446894898
Please anyone can help to find the issue and how we may resolve it?
Appreciate your time and efforts for me.
Thanks and Regards
Giuseppe Larosa Sat, 10/25/2008 - 07:39
  • Hall of Fame,
    Founding Member
Hello Devender,
there is something strange in the output :
-92 packets/s forwarded is not real.
to get better help more details are needed:
What platform and what IOS release runs on ds1 ?
if a catalyst 6500 issue sh ver and sh module and post here
if you like post a filtered version without public unicast ip address (don't care about multicast addresses in range 239 they are private addresses).
Most of drops are not caused by RPF failures but by other reasons including OI list null.
So not only verify if packets are arriving from the same L3 interface that would be used for routing unicast packets directed to the source 155.x.x.x (this is the RPF check)
Check also if your PIM is partitioned and receivers cannot join the group.
PIM must be enabled on all interfaces where you are running the unicast routing protocol to avoid that a link failure can partition the Multicast routing domain.
For the high cpu usage post
sh processes cpu sorted 1min
this can tell exactly what processes are more cpu intensive.
Hope to help
Giuseppe
derawat28 Sun, 10/26/2008 - 03:38
DS1#sh version
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-VM), Version
12.2(33)SXH1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 17-Jan-08 07:19 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
DS1 uptime is 23 weeks, 1 day, 21 hours, 36 minutes
Uptime for this control processor is 23 weeks, 1 day, 21 hours, 35 minutes
Time since DS1 switched to active is 23 weeks, 1 day, 21 hours, 35 minutes
System returned to ROM by reload at 18:00:12 Singapo Fri May 9 2008 (SP by reloa
d)
System restarted at 20:54:36 Singapo Fri May 16 2008
System image file is "bootdisk:s72033-ipservicesk9_wan-vz.122-33.SXH1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C6506-E (R7000) processor (revision 1.1) with 1040384K/8192K bytes of m
emory.
Processor board ID SAL1212K0EE
SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
10 Virtual Ethernet interfaces
75 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Patching is not available since the system is not running from an installed imag
e. To install please use the "install file" command
DS1#sh mod
Mod Ports Card Type Model Serial No.
1 24 CEF720 24 port 1000mb SFP WS-X6724-SFP
5 5 Supervisor Engine 720 10GE (Active) VS-S720-10G
The process which high at the time of high CPU is "IP Input".
When we take out the ACL so our all receiver can get the multicast program from the source.
May I know how may I do my further investigation (I mean can you suggest some of the commands?)?
You might feel silly to ask you as mentioned above but as I am not so smart in Multicast so I hope you will assist me.
Thanks a lot.
Devender
Giuseppe Larosa Sun, 10/26/2008 - 03:56
  • Hall of Fame,
    Founding Member
Hello Devender,
for RPF check use
sh ip rpf
to verify if you have enabled PIM on all the required interfaces
compare the output of
sh ip pim interface
with a show for your current unicast routing protocol
for example
sh ip ospf interfaces
OR sh ip eigrp interfaces
And also:
sh ip pim neighbors
sh ip ospf neighbors OR sh ip eigrp neigh
This has to be done also on the routers/switches were the receivers are connected.
the ip pim sparse-dense-mode or other type must be enabled on all involved L3 interfaces: the one where is the source, those where there are the receivers and all the backbone links to be able to build the distribution tree
Hope to help
Giuseppe
derawat28 Sun, 10/26/2008 - 22:10
Hi Giuseppe,
Thanks again for taking interest and for your helping hand.
I have checked all the interfaces for the PIM and OSPF on source DS as well as receviers DS and I can see all the interfaces are enabled with PIM- sparse-dense mode.
#### Below is the output from the source side###
DS1#sh ip rpf
RPF information for ? (source IP add)
RPF interface: Port-channel16
RPF neighbor: ? (x.x.x.x)
RPF route/mask: x.x.x.0/25
RPF type: unicast (ospf 1)
RPF recursion count: 0
Doing distance-preferred lookups across tables
DS1#sh ip mroute 239.192.10.102 count
17 routes using 19672 bytes of memory
5 groups, 2.40 average sources per group
#sh ip pim interface
172.x.x.x Vlan252 v2/SD 0 30 1 0.0.0.0
DS1#sh ip ospf interface
Vlan252 is administratively down, line protocol is down
Internet Address 172.21.252.252/23, Area 0.0.0.236
Note: I dont know why my client has shut this vlan however according to me this vlan should be up as it belongs to source subnet.....???
##### On Receiver Side######
ds1#sh ip rpf
RPF interface: Vlan252
RPF neighbor: ? (source IP add) - directly connected
RPF route/mask: x.x.x.0/25>>>>>> Source subnet
RPF type: unicast (connected)
ds1#sh ip pim interface
x.x.x.124 Vlan252 v2/SD 1 30 1 155.69.252.125
s1#sh ip ospf interface
Vlan252 is up, line protocol is up
I hope now you will have more clear picutre and will be able to suggest in more details.
Thanks a ton.
gnijs Thu, 11/06/2008 - 13:17
  • Bronze, 100 points or more
I don't think redundant non-RPF traffic is the cause. He is using a VS-S720-10G supervisor. non-RPF traffic should be dropped in hardware.
cisco_lad2004 Wed, 11/05/2008 - 02:54
  • Gold, 750 points or more
what ttl value for the multicast address causing high CPU ?
If its 1, it be punted to CPU.
U could debug on the upstream device ( so u dont make a struggling router even worse) or ask the servers guys to check what TTL value is the stream coming out with.
Sam
Amit Singh Wed, 11/05/2008 - 03:27
  • Cisco Employee,
I agree with SAM on this. Once of my customer faced the same problem a couple of months back and we found out the application which was generating the multicast streams had a ttl of 1 due to which arre the packets were processed by the CPU. Changing the TTL to 10 in out case helped us bringing down the CPU.
-amit singh
derawat28 Fri, 11/07/2008 - 04:50
Thanks for you all for your time and interest in my issue.
I would like to share again that as long as there is ACL in our Ds for deny 239.x.x.x it is not going to cause CPU high but at the movement we are taking it off CPU rising very fast.
My concerned is for my two multicast channel as after key in this ACL we are not being able to reach those two channel but when we are using the group ID 224.x.x.x there is no issue and we can reach to multicast channel and also not causing CPU high.
Currently those two channel are in the multicast group 239.x.x.x
Thanks and Regards
cisco_lad2004 Fri, 11/07/2008 - 05:00
when u use ACL u are blocking multicast stream...so nothing hits CPU. when u remove it, any multicast groups with ttl one will hit ur CPU.
so please check ur ttl.
derawat28 Fri, 11/07/2008 - 05:02
HI,
With great thanks, can you please tell me how may I check that?
cisco_lad2004 Fri, 11/07/2008 - 05:32
2 options:
1-ask the server guys who are setting up ttl values before they stream multicast.
2-run a debug on teh upstream device before the one with high CPU ( so u don't kill ur box).
debug ip mroute 239.x.x.x
alternatively, u could just ask the server guys to increase TTL value. when they are done, remove ACL and validate CPU is ok.
let us know how it went.
Sam
gnijs Fri, 11/07/2008 - 05:43
See if the router is sending a lot of TTL Expired messages:
sh ip traffic | i time exceeded
If this counter is increasing rapidly, this is a strong indication.
Alex.DEPREZ Wed, 11/27/2013 - 07:50
I know this topic is old, but since this is the first result on google concerning high cpu and multicast.
I resovled a similar problem, an HD IPTV Streamer flooding on 32 multicast groups, 4500-X CPU raise to 100% each time I activate PIM on the interface facing the streamer. The multicast groups were 239.x.x.x , changed to 225.x.x.x and everything worked fine.
Still looking for an explanation regarding this
