Cisco CUE
hadisharifi
Hi, I for the first time have started playing with Unity Express on a Cisco 2811, after reading around I have configured the following in order to get into the Unity GUI, however I am not able to ping the UE interface. Can someone please tell me why I can't ping the service-engine interface?
What is the Fa0 interface for on the NM-CUE?
interface Service-Engine1/0
ip unnumbered Loopback0
service-module ip address 10.1.250.1 255.255.255.0
service-module ip default-gateway 10.1.250.101
interface Loopback0
ip address 10.1.250.101 255.255.255.0
Markus Schneider
You need a host route for sure.
ip route 10.1.250.1 255.255.255.0 service-engine 1/0
CUE has ping commands and 'show int'; as long as the module is up (serv serv 1/0 status) you should be able to ping it. Make sure you can first ping it from the router itself, then a host behind the router.
