10-26-2008 03:22 AM
I have configured ACE in bridged mode. Connection to VIP from the client to the server VLAN is happening. But any connection to VIP from the server itself in the same server VLAN is failing as CON_CLOSE. Is SNAT required in bridged mode.
Please assist.
SHOW SERVICE-POLICY DETAIL
Service-policy: LB-VIP-FROM-SERVER
class: VIP-ACE-XXX-HTTP
VIP Address: Port:
172.18.90.200 eq 80
loadbalance:
L7 loadbalance policy: LB-ACE-XXX
VIP Route Metric : 77
VIP Route Advertise : DISABLED
VIP ICMP Reply : DISABLED
VIP State: INSERVICE
curr conns : 0 , hit count : 25
dropped conns : 25
client pkt count : 39 , client byte count: 1840
server pkt count : 0 , server byte count: 0
L7 Loadbalance policy : LB-ACE-XXX
class/match : class-default
LB action :
sticky group: ACE-XXX-STICKY
primary serverfarm: ACE-XXX
state: UP
hit count : 33
dropped conns : 0
Below show capture
0018: msg_type: PKT_XMT con_id: 1375731816 other_con_id: 0
0019: msg_type: CON_CLOSE con_id: 301989991 reason: 0
0020: msg_type: CON_CLOSE con_id: 1375731816 reason: 0
src_addr: 172.16.10.99 src_port: 2674
dst_addr: 64.91.231.55 dst_port: 110
l3_protocol: 0 l4_protocol: 6
message_hex_dump:
0x0000: 0000 0102 5200 0068 0000 0000 0000 0000 ....R..h........
0x0010: ac10 0a63 405b e737 0629 0002 0a72 006e ...c@[.7.)...r.n
0x0020: 68af f25e 051b 1400 0564 0180 1200 0067 h..^.....d.....g
0x0030: 0000 0000 0018 0480 2445 0000 0000 0008 ........$E......
0x0040: 0000 017f ffae 004e c056 8f8c f5d8 65a5 .......N.V....e.
0x0050: c056 8f8c 0a89 38a5 0000 0000 0000 0119 .V....8.........
0x0060: 0000 0000 0a89 317f 0000 0000 0000 0000 ......1.........
0x0070: 405b e737 ac10 0a63 0621 0001 006e 0a72 @[.7...c.!...n.r
0x0080: 9750 0da2 0536 1400 05b4 0180 5200 0068 .P...6......R..h
0x0090: 0000 0000 0018 0480 2445 0000 0000 0009 ........$E......
0x00a0: 0000 01bd 16d0 004f 8d28 7347 57a6 9d2e .......O.(sGW...
0x00b0: 8d28 7347 0a89 39ca 0000 0000 0000 0119 .(sG..9.........
0x00c0: 0000 0000 0a89 317f 0000 0000 ......1.....
10-26-2008 03:43 PM
You need to
1. Source nat the Server initiated traffic
2. & Apply a service policy on Server side vlan
Something in line of...
policy-map type loadbalance first-match App1-policy
class class-default
serverfarm APP1-SF
policy-map multi-match VLAN10-VIPs
class VIP-App1
loadbalance vip inservice
loadbalance policy App1-policy
loadbalance vip icmp-reply
policy-map multi-match Server2VIP
class VIP-App1
nat dynamic 10 vlan 20
interface vlan 10
bridge-group 10
access-group input all-traffice
service-policy input MGMT
service-policy input VLAN10-VIPS <-- policy for all VIPs
no shutdown
interface vlan 20
bridge-group 10
nat-pool 10 10.10.10.199 10.10.10.199 netmask 255.255.255.0 pat
service-policy input Server2VIP <- Policy for Servers hitting VIP
no shutdown
For details why you need these modifications. Please read my previous post at
Syed Iftekhar Ahmed
10-26-2008 04:19 PM
Thanks.
What is loadbalance vip icmp-reply used for.
Other than the above, I am experiencing an issue with SSL. I have configured ssl-proxy on the policy-map for VIP eq 443 on server side vlan 'only'. However, I can see that from the servers in the Server vlan, accessing the VIP URL via http (80) prompts for the SSL certificate.
Can this happen ? Can a misconfiguration on ACE cause this (may be multi-match policy for server side vlan) ? Or even a misconfiguration on the server. The SSL is terminated on the ACE.
Regards.
10-26-2008 04:50 PM
Vip icmp-reply active enables VIPs to responds back to icmp requests destined towards VIP IP.
Why do you have ssl-proxy defined on Server-side vlan?
(Without server2vip traffic requirement) following should be the sample config.
class-map match-all HTTPS-APP1
match virtual-address 10.10.10.10 tcp eq https
policy-map type loadbalance first-match APP1-POLICy
class class-default
serverfarm APP1-SERVERS
policy-map multi-match VLAN10-VIPS
class HTTPS-VIP
loadbalance policy APP1-POLICy
loadbalance vip icmp-reply active
ssl-proxy server APP1-SSL-SERVICE
interface vlan 10 <-- client Vlan
bridge-group 10
no shutdown
interface vlan 20 <-- Server Vlan
bridge-group 10
no shutdown
1. In above config "APP1-SSL-SERVICE" will decrypt the traffic.
2. Decrypted traffic will be loadbalanced by "APP1-POLICY"
If your class-map is only filtering HTTPS traffic then SSL service should be applied on port 80 traffic.
Do you have a port 80 rule/VIP for the same app?
If yes then hit the server directly on port 80 and make sure that it is not misconfigured and is not throwing the cert.
Syed Iftekhar Ahmed
10-27-2008 04:35 AM
The application team requires https on server vlan as well.
I have checked my configs. Hitting port 80 on VIP prompts with the cert. Strange..... Please see below. Is ever it possible that the application server somehow replies to the client to resend the request on port 443 instead of 80 which throws up the cert from ACE. Other than that it is difficult to understand how can this happen.
The result of : http://www.xxx.com (cert is thrown up)
VIP Address: Port:
10.0.0.200 eq 80
loadbalance:
VIP ICMP Reply : ENABLED
curr conns : 0 , hit count : 1
dropped conns : 0
client pkt count : 7 , client byte count: 1361
server pkt count : 6 , server byte count: 1464
LB action :
state: UP
hit count : 4
dropped conns : 0
Class-map rule:
class-map match-all VIP-ACE-XXX-HTTP
2 match virtual-address 10.0.0.200 tcp eq www
policy-map multi-match LB-VIP-SERVER-VLAN
class VIP-ACE-XXX-HTTP
loadbalance policy LB-ACE-XXX
class VIP-ACE-XXX-HTTPS
ssl-proxy server testssl_proxy
class REAL_SERVERS
nat dynamic 1 vlan 99
interface vlan 99 <--- Server VLAN
bridge-group 1
access-group input PERMIT-VLAN-TRAFFIC
nat-pool 1 10.0.0.120 10.0.0.120 netmask 255.255.255.0 pat
service-policy input permitall
service-policy input LB-VIP-SERVER-VLAN
no shutdown
Please assist.
10-27-2008 06:03 AM
Ok.
One more thing. When I access the rserver locally (i.e. http://www.xyz.com:7777/test , it still prompts for the certificate. (Note: the VIP was on port 80 which translates to 7777 on the rserver).
It means that the local rserver some how gets in touch with the ACE for the cert or has it locally stored. Head spinning...
10-27-2008 10:45 AM
If I understand correctly then you hit your real server directly (bypassing vip) on port 7777 and you got the cert.
Ace has nothing to do with it (As you are not hitting VIP, ACE is simply routing to/from the real server). It means you rserver is configured with SSL certificate.
What is the objective?
As per your configs you are doing SSL offload but if your server is doing SSL then you need to do end2end ssl.
Syed Iftekhar Ahmed
