Questions on Voicexml
Oct 26th, 2008
I have a case that need to use the IP IVR to call the external Voicexml without ASR or TTS. To make it simple, I just use the play prompt feature. As regards the IP IVR part, I use the voice browser application to call the Voicexml document which is put in another Web server. However, it prompts out a java exception.
I have no idea on what problems are there. Was my configuration on the system missed something?
Many Thanks.
