ISDN BRI ip telephony
zeuscyril
Level 4
Level 4
hello friends,
i want to configure ISDN BRI ip telephony. .
but i dont know how to configure isdn parameters.plz help me in this.
i am using WIC 1B S/T-V3 card using .will it support for normal ip telephony..if u have any model con fig send me..
i am having doubt that we need use vic card...
thanks
9 Replies 9
Aaron Harrison
The data WIC you have will not support Voice.
The correct card for voice applications is VIC2-2BRI-NT/TE.
Aaron
Please rate helpful posts!!
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
thank u
so if we use WIC 1B S/T-V3 the ip telephony will not work.so we use only vic cards
send some example config for isdn
thanks
the vic cards will vary for each country or we can use any vic card for bri voice...my country is UAE..
reply me
thanks
hi friends thank u all for ur reply....
i configured a isdn bri line using vic2-2bri-nt/te.
i configured every thing.but i am able to call lanaline numbers but i am not able to call mobile and international.i didnt block 0 and 00.and i checked with isp they also saying not blocked....
so any reason is there behind this
like vic card or any commands in isdn bri..
because first time i am configuring isdn bri for voice
thanks
cyril
I am also configuring CCME using VIC2-2Bri-nt/te, so could you please send me complete configuration. I am unable to call any PSTN no...so help me..
Thanks in advance.
if anyone having E1 configuration in Saudi Arabia please share.....
Sharma: search the forum, there are numerous examples.
Eldho: Ditto, or open a new thread.
Hello Ditto,
I am setting up VOIP call between 2 2801 router using DSL as Primary link and ISDN as secondary link.My calls thrugh the DSL if fine and no issue.I face issue in the below situations.
1-When it fallback to the ISDN the active calls disconnects and it becomes UNIDIRECTIONAL.If I initiate new call that works fine i.e. Bidirectional.
Do you have any solution for this ?
2-Setting up a VPN tunnel between ISDN and DSL will ressolve issue ?
3-I am also unable to dial the PSTN no., it gives reorder tone if I try to access line using either "0" or "9".
Kindly help.
Thanks in advance.
Vijay
Hi, as mentioned above you should open a new thread for a different questions.
Also note, in english, "ditto" means "same as above".
