WPA on CIsco 1120
Answered Question
Oct 26th, 2008
Hi All, new to the wireless world, I have a config that a co-worker that swears works to enable WPA-PSK on the WAP heres what he laid out for me:
dot11 ssid SUSD-LAB
authentication open
authentication key-management wpa
guest-mode
infrastructure-ssid optional
wpa-psk ascii fakepassword
interface Dot11Radio0
encryption mode ciphers aes-ccm tkip
ssid SUSD-LAB
Unfortunately it seems that aes is not an option on the 1120. When I substitute the "aes-ccm" for "tkip wep128" I get the following statement from the WAP:
"WPA mandatory key mgmt requires TKIP only no WEP delete key mgmt under ssid before changing cipher"
Any suggestions I have configured this offsite so I have not have a chance to see if this will still work.
thanks,
Mike
Correct Answer by jeff.kish about 8 years 8 months ago
You should also eliminate the infrastructure command under the SSID. Not a big deal, but you don't need that unless you're planning to perform bridging connections with this AP.
You can perform both TKIP and WEP, but it's not recommended since this provides a backdoor into your wireless network. The only reason you should do that is if you have clients that only support WEP.
Other than that, just do what Gerald says.
Overall Rating: 5 (1 ratings)
Gerald Vogt Mon, 10/27/2008 - 01:02
  • Bronze, 100 points or more
If the 1120 does not support WPA2/AES-CCM then only set up TKIP. Leave out the aes-ccm for WPA2 connections, i.e.
encryption mode ciphers tkip
aes-ccm is used in WPA2.
Correct Answer
jeff.kish Mon, 10/27/2008 - 05:50
  • Silver, 250 points or more
carbonscoring Tue, 10/28/2008 - 19:18
Thanks guys for the suggestions. Will follow both reccomendations.
Mike
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
