How to take backup of router
Oct 26th, 2008
Please educate met about how to take backup of router when it is connected through console?
Overall Rating: 4 (2 ratings)
bagvanliju Mon, 10/27/2008 - 01:35
is your requirement to take back up of running config.??if so
Router#show Run (you can copy and paste in a notepad.)
in Hyperterminal there is on option of capturing the text (Tranfer capture text) give a file name (Router#show run)
am i able to fullfill the requremnt if not let us know ...
ccnpninja Mon, 10/27/2008 - 13:36
Another option (through the network, not the console) is to copy either the running config or the startup config to a TFTP Server.
#copy running tftp
then IOS asks you a few questions such as: IP address of the TFTP server, name of the new file,...
Of course, you should have a TFTP Server running at the IP address that you'll give.
plz rate if it helps.
kalshetty Mon, 10/27/2008 - 23:00
Thanks. Its works. Only I have the problem with the cable which I used for connecting to router to PC.
