CCSP Progress
Answered Question
Oct 27th, 2008
Dear,
I have done the following exams on the track to CCSP.
642-522(SNPA),642-502(SNRS). I am planning to sit 642-691(BGP+MPLS) to complete my CCIP(I have already done QOS&COMPOSITE).My question is,If I completed my CCIP, what are the exams that I need to cover to get CCSP.
Kindly give your valuable advice.
Thanks & Regards
Correct Answer by Rob Huffman about 8 years 2 months ago
Hi Gopakumar,
First off, you are most welcome! Glad to help. Your CCIP Cert will not help to bypass the SND and there is no overlap in exams between the two Cert Paths. The nice thing is that you have already passed two of the exams along the path to the CCSP and it sounds like you are very close to achieving the CCIP as well.
Hope this helps! And best of luck on your journey.
Rob
Overall Rating: 5 (2 ratings)
Rob Huffman Mon, 10/27/2008 - 09:43
Hi Gopakumar,
If you started right away and passed the SND exam before November 17 of this year you would follow the "old" 4 plus 1 blueprint. If you wait to start, then the "new" 3 plus 1 model will be required. Either way, you have completed 2 of the "Required" Exams.
The difference is that in the new 3 plus 1 model you also require the newly released "CCNA - Security" certification.
Cisco Certified Security Professional Prerequisite
CCNA Security
OR
CCNA + SND*
*SND last day to test is November 17, 2008.
Candidates for CCSP will now need only four exams (three required, one elective) with the introduction of the new CCNA Security as a prerequisite, instead of the five exams required today (four required, one elective). ** Retired exams that have been passed may be used towards exam requirements for three years.
***You will need 4 of these in the "old" model and 3 in the "new" model;
642-552 SND
Last day to test 11/17/2008
642-503 SNRS
642-523 SNPA
Last day to test 1/16/2009
642-524 SNAF
Available 8/29/2008
642-533 IPS
***You will need 1 of these in either model;
Elective Exam(s)
642-513 HIPS
OR
642-591 CANAC
OR
642-544 MARS
OR
642-515 SNAA
Available 8/29/2008
http://www.cisco.com/web/learning/le3/le2/le37/le54/learning_certification_type_home.html
Hope this helps!
Rob
gopakumarmk Mon, 10/27/2008 - 22:45
Dear Rob,
Thank you for your post.
The details that you covered in the post was very helpful to me.
One more question, So my CCIP certification won't help to bypass the SND exam, is it?
Does the Cisco consider CCIP certification has one of the required exam for CCSP?
Please advice.
Correct Answer
Rob Huffman Tue, 10/28/2008 - 05:24
Hi Gopakumar,
Rob
Hi, im sorry to interupt in the middle of the post, but im working towards my CCSP certification, but as of now i only got CCNA Sec and the elective; 642-591 CANAC.
Im gonna take the 642-523 SNPA before the last day to test, but would this mean i only need two of:
642-533 IPS
642-503 SNRS
642-524 SNAF
Or would the SNPA overtake the SNAF ?
Thanks in advance.
Rob Huffman Fri, 11/14/2008 - 10:04
Hi Svein,
You are in great shape :)
You would need only two more of these;
642-533 IPS
642-503 SNRS
642-524 SNAF
Hope this helps!
Rob
