Upgrade CCM 6.0
Oct 27th, 2008
Hii Experts,,
If I want to upgrade CCM 5.0 to 6.0. What I have to do? and PLZ tell me if it is enough to upgrade from 5.0 to 5.1 using cisco-ipt-k9-patch5.1..., and do the same steps to upgrade from 5.1 to 6.0 using cisco-ipt-k9-patch6.0.1.2000...., Do I have to make a backup to from 5.0 and restor it to 5.1 and then to 6.0 or it is enough to restore it in 6.0 without 5.1.
PLZ need you help.
Overall Rating: 4 (1 ratings)
Jaime Valencia Mon, 10/27/2008 - 11:45
you can look at the tables to know the upgrade path here:
Table 4 Supported Cisco Unified Communications Manager Upgrades for Release 6.x and Release 7.x
most of the patches available on CCO are for specific upgrades so check which ones are available to plan the upgrade path.
upgrade guides are here, take some time to review them. how to backup is also covered under DRS, also read the info
Install and Upgrade Guides
Maintain and Operate Guides
if this helps, please rate
