Warning message
How to configure RMON traps on Cisco ISR 3845
Oct 27th, 2008
I want to configure RMON to monitor tunnel interfaces on Cisco 3845 router.
I tried to search but the configuration which i found is not functional on my routers.
Can anyone help ???
IOS Version 12.4(3g.
Thanks.
S. Hasan Mon, 10/27/2008 - 22:19
hello,
Thanks for your reply.
I had already viewed this document but it is not solving my problem, i have to run rmon on tunnel interface, is there any way out to get rmons traps of tunnel interfaces.
rgds, Raheel
Joe Clarke Mon, 10/27/2008 - 22:23
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
RMON doesn't care about the interface type. RMON allows you to watch a MIB object to see if it crosses a certain threshold. Provided there is such an object for your tunnel interfaces, then the document to which I pointed you should be sufficient to configure your RMON events and alarms. Exactly what do you want to monitor on this tunnel interface? What MIB object?
