logging buffer-size 50000 - in PIX
Answered Question
Oct 27th, 2008
Hi all,
Could you please tell me what is the default buffer size in PIX and if we can increase it or not?
I also need to understand "logging buffer-size 50000" in terms of KB/MB?
Thanks in advance
Vin
Correct Answer by ajagadee about 8 years 7 months ago
Vinay,
The default log buffer size is 4 KB of memory. And the value 50000 is in bytes. Please refer the below URL for details.
http://www.cisco.com/en/US/docs/security/asa/asa70/command/reference/gl.html#wp1654419
Arul
*Pls rate if it helps*
Overall Rating: 5 (1 ratings)
Farrukh Haroon Mon, 10/27/2008 - 06:08
  • Red, 2250 points or more
The default is 4096 (4K). It is defined in 'bytes'.
Farrukh
