Busy Indicator for Receptionist Phone
Answered Question
What seems like a simple task has turned out to be a real pain. I'm trying to configure line buttons on a 7914 sidecar that will simply light up when whatever phone it's configured with goes off hook.
I initially tried this with a shared line appearance. The problem with this is any incoming call to the configured line flashes on the phone's screen, even if the ring settings are set to "Disabled"
Next I tried to set up a BLF SD button ( saw "Busy Lamp" and got excited), however it doesn't light up when the phone is off hook.
Any ideas on how to accomplish this? Thanks in advance.
Overall Rating: 5 (1 ratings)
Rob Huffman Mon, 10/27/2008 - 06:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Patrick,
Are you using Communications Manager (version?) or Communications Manager Express?
Rob
Correct Answer
Rob Huffman Mon, 10/27/2008 - 06:21
  • Hall of Fame,
    Founding Member
Rob Huffman Mon, 10/27/2008 - 06:46
  • Hall of Fame,
    Founding Member
Hi Patrick,
You are most welcome :) Glad to be of some small help.
Cheers!
Rob
