Unable to configure local AAA authentication
Oct 27th, 2008
In my Cisco ASA 55220 , I am unable to configure AAA.ASA is configured in transparent mode.
Please find the error msg..
ASA-MPLS(config)# aaa authentication enable console loCAL
ERROR: aaa-server group loCAL does not exist
Usage: [no] aaa mac-exempt match <mac-list-id>
[no] aaa authentication secure-http-client
[no] aaa authentication listener http|https <if_name> [port <port>] [redirect]
[no] aaa authentication|authorization|accounting include|exclude <svc>
<if_name> <l_ip> <l_mask> [<f_ip> <f_mask>] <server_tag>
[no] aaa authentication serial|telnet|ssh|http|enable console
<server_tag> [LOCAL]
[no] aaa accounting telnet|ssh|serial|enable console <server_tag>
[no] aaa authentication|authorization|accounting match
<access_list_name> <if_name> <server_tag>
[no] aaa authorization command {LOCAL | <tacacs_server_tag> [LOCAL]}
[no] aaa accounting command {privilege <level>} <tacacs_server_tag>
[no] aaa proxy-limit <proxy limit> | disable
[no] aaa local authentication attempts max-fail <fail-attempts>
clear configure aaa
clear aaa local user {fail-attempts|lockout} {all | username <uname>}}
show running-config [all] aaa [authentication|authorization|accounting
|max-exempt|proxy-limit]
show aaa local user [lockout]
ASA-MPLS(config)#
Please guide to resolve this issue..
som
Overall Rating: 4.6 (9 ratings)
Premdeep Banga Mon, 10/27/2008 - 06:24
  • Gold, 750 points or more
Use "LOCAL" not "loCAL"
Prem
Please rate if it helps!
elizer man-on Wed, 02/11/2015 - 05:13
This old post help my two days without sleeping in the night problem.
thank  you Premdeep.
Rex
meahmedhassan Wed, 11/16/2016 - 04:27
if you use the "local" key in small letters the ASA would consider it as a different aaa server over its default of "LOCAL" with capital letters, same concept for any other aaa server different than the default existent one.
Please try again by using the command with "LOCAL" key in capital letter. because the local server name is a case sensitive
