How can i check deny log for a particular IP in PIX
Answered Question
Oct 27th, 2008
How can i check deny log for a particular IP in PIX?
bit urgent request
thanks to everyone in advance
Correct Answer by Collin Clark about 7 years 11 months ago
With high traffic flow it's very hard to see.
Overall Rating: 5 (1 ratings)
vintan1801 Mon, 10/27/2008 - 06:43
as internal buffer size is not very big in PIX- it might not be having it. Is there any other way i can check the deny logs?
Collin Clark Mon, 10/27/2008 - 06:47
You really have two options-
Make the buffer larger (still have a chance of missing it though).
logging buffer 16000
Or send the logs to syslog and review them off the server (preferred method)
logging host [ip address of syslog server]
Hope that helps.
vintan1801 Mon, 10/27/2008 - 06:55
Good option. so it means that definitely i might not be able to see any deny entry for a particular IP (i.e, if the traffic flow is very good on the firewall and buffer size set was to low)??
vintan1801 Mon, 10/27/2008 - 07:08
Thank you for your advice - very informative and quick.appreciate it. if i need to give you rating how can i do?
