CME AA not working
kennis1977
Hi there,
I want to get a simple welcomemessage from my cme aa.
However i build it like the config attached but you don't hear anything..
Can anybody help me?
application
service aa flash:app-b-acd-aa-2.1.2.2.tcl
paramspace english index 0
paramspace english location flash:
param handoff-string aa
paramspace english prefix en
param welcom-prompt en_bacd_welcome.au
param aa-pilot 2040
dial-peer voice 2040 voip
destination-pattern 2040
session target ipv4:1.1.1.1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 2041 voip
service aa
incoming called-number 2040
codec g711ulaw
no vad
7 Replies 7
don-sullivan
The .tcl scripts for rotuers are very specific with their use of variables and filenames.
Please start with the above. Make sure within the AA configuration it states.
param welcome-prompt _bacd_welcome.au
Next you have to have a dial-peer configured to use the script. Your above configuration states when dialing ext 2040 have ip address 1.1.1.1 answer the call. You should have a command within the dial-peer for the script to process it. For example.
dial-peer voice 2040 pots
service aa
metalium2007
Level 3
Level 3
if the script is to process an incoming voip call you should not use a pots dial-peer like stated.
Is the script for an incoming voip or pstn call?
Rgds,
Met.
(then check the parameter like Don said and also check/try:
i'm using and working like this:
service aa flash://app-b-acd-aa-2.1.2.2.tcl
CMEs sometimemes are weird with paths.)
Ok...im going to try that...
i keep you guys up to date...
Thanks for your reply...
The script is for an incmoing pstn call by the way...
Ken,
If its an incoming pstn call, try one dial-peer pots:
dial-peer voice 2041 pots
service aa
port
So that the number matches the script!
hth,
Met.
What i have is an analog pstn line,and i use a connection plar opx 2040 on my voice-port.
so what will be the best config to use in this case..?
Should i use a dial-peer pots or voip..?
and do i need a session-target ipv4 command?
or only a service aa ?
Can you give me a small config on how you should configure this situation.?
Thanks again..
2040 is the extension that you need to default to when call is answered by the script (option 0 operator, i think).
1. Make the script grab the incoming call;
2. Default operator extension to 2040;
hth,
Met.
