Cisco View - File does not exist
Oct 27th, 2008
I am getting this error because I am viewing the LMS website from my workstation and not the server LMS was installed on.
Is there a way (via reg key or configuration change) that I can make my workstation point to a server share for this file? ex \\server\d$\program files\cscopx\htdocs\cvng\
Thanks for any help provided.
Error: The requested URL cannot be reached because File does not exist: d:/program files/cscopx/htdocs/cvng/chassis.do
Description: 404 Not Found is the HTTP status code returned by the Apache web server if it has not found anything matching the requesting URL.
Joe Clarke Mon, 10/27/2008 - 09:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Exactly what did you you do (step-by-step) to encounter this error? This kind of URL should not be seen when accessing LMS via the web.
Jason Fraioli Mon, 10/27/2008 - 09:15
CM->Topology Services
I am viewing the Layer 2 Topology, but it does this any time I click on the Cisco View.
In topology services, I right click on a switch (3750) and select Cisco View.
The Error:
Please verify if the URL correct on your browser's location bar or your browser's bookmarks.
The Link:
http://lms_server:1741/CVng/chassis.do?deviceip=172.20.5.22
Joe Clarke Mon, 10/27/2008 - 10:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What version of CiscoView is this?
