ranpierce Mon, 10/27/2008 - 07:28
  • Silver, 250 points or more
Yes at the opening greeting instead of pressing ext to ring the phone. Press ext#2 and it will go directly to voice mail of the extensions diales.
Hope this is what you wanted.
Randy
l.colmenares Mon, 10/27/2008 - 07:35
Thank you for your answer.
I guess my question wasn't clear enough.
From the user point of view, is there any way to callforward to voicemail without the softkey CFwdALL from the phone or the CCMUser website?
we want to allow Call Forward to local calls to all people in the company, but only from the CCMUser WebSite.
We would acomplish this by removing the softkey CFwdALL.
Then users would have the access to forward to their voicemail from the phone. They would have to go to the CCMuser Website.
So, is there any way to forward to voicemail from the phone without the softkey CFWdALL?
Thank you
Chris Deren Mon, 10/27/2008 - 07:38
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Sorry, but if you remove the softkey there is no other way to forward the call to VM from the phone. Maybe unplugging it and having the phone's ForwardUnregistered to go to VM :-)
HTH,
Chris
ranpierce Mon, 10/27/2008 - 07:56
The instructions I gave do not involve the softkey.
Randy
Chris Deren Mon, 10/27/2008 - 08:04
  • Hall of Fame,
Your instructions assume the call is already in VM, so it would apply if calls are coming to Unity AA, but what if a call comes in directly to the phone via a DID?
Chris
ranpierce Mon, 10/27/2008 - 08:32
you are correct my intructions if the call came to Unity AA.
Hmm.
There is a way to take soft keys off. But to do what you want you either have to use softkeys or ccmuser I think.
Randy
