3845 onboard VPN counters question.
Oct 27th, 2008
We use 3845`s to terminate some branch offices with a IPSec/GRE tunnel.
However ive noticed that when doing the stats on the onboard cryto card I get a error I can`t find any info on and wondered if anyone on here had come across it ?
Errors:
0 pkts dropped 0 ppq full
0 tx parts overflow 0 rx parts overflow
0 replenishment failure 0 zero len
0 flow inputs bad 0 cmd invalid
0 IPV4 len 0 algor invalid
0 bad shadow particle 0 algor disabled
0 pre tx fail 0 dma error
0 dbit miss 0 pipeline abort
0 failsafe timeout 0 reserv
0 bad sz count 0 bad shdw
0 bad flow tx 0 spi mismatch
0 bad flow rx 0 auth fail
0 udm fs fail 0 pad fail
0 addr limit fixup fail 0 seq fail
250756555 quad fix sp 0 quad fix mp
0 quad fix cont
vmoopeung Mon, 11/03/2008 - 14:03
  • Bronze, 100 points or more
This looks like an encryption issue. You can find the workaround for the similar kind of issue in the bug bug ID “CSCsd47513".
achrich Tue, 11/04/2008 - 00:09
Thanks for the reply how ever the version of IOS used is not listed for that bug.
3845 is running 12.4-13d.
CPU is running at approx 40% which is what we would expect when encrypting approx 60-70Mb ( wth varying packet sizes )
nicolas.mayor Tue, 09/22/2009 - 05:11
Hi Ahrich,
I got the same issue with a 12.4(13r)T, but CPU is 20% and I lost 1% traffic.
Did you manage to solve this problem ?
Thanks and best regards
