10-27-2008 08:12 AM - edited 03-15-2019 02:11 PM
I would like to have all of my users call into a number to check their voicemail. Insted of them dialing into their own number. Possible?
Solved! Go to Solution.
10-27-2008 08:30 AM
Absolutely. I'm assuming you're using Callmanager and Unity. Set aside a DID number for this purpose. Create a translation pattern that translates the DID to the Hunt Pilot for Unity. You can also setup alternate extensions in Unity for mobile phones, etc. so when users call from these numbers they are only prompted for password and not extension/password.
Hope this helps. If so, please rate the post.
Brandon
10-27-2008 08:29 AM
Sure, cofigure that number as cti route point for example in CallManager and set forward all to VM. In Unity create a forward routing rule that matches this number and sends it to "Sing-in" handler.
HTH,
Chris
10-27-2008 08:32 AM
I'm a little too slow this morning, Chris. This is definitely another way to accomplish the goal.
Brandon
10-27-2008 08:30 AM
Brandon
10-27-2008 09:19 AM
Callmanage 6.1 and Unity Connection 2x
10-27-2008 09:49 AM
Earlier posts apply.
Brandon
10-27-2008 11:03 AM
I added my cell phone as an alternate extension but it is still prompting me for my id and password. Not just password
10-27-2008 08:49 AM
Of course, neither of these solutions will prevent users from dialing their own extensions to get VM. Can we prohibit Alternate Extensions and remove the * function to backup from the Subscriber voicemail menu?
10-27-2008 11:14 AM
bbuffins respomse works. You do not have to eneter *. Although the alternate extension would be sweet. I did as he said but its still prompting me for my id when I call from my cell phone.
