Jaime Valencia Mon, 10/27/2008 - 11:42
  • Cisco Employee,
  • Hall of Fame,
    2011
i'd check disk space on unity and if the message store is mounted, if both good then permissions wizard and MSCW -sync
java
if this helps, please rate
esa786_2 Mon, 10/27/2008 - 20:30
How to check whether message store is mounted?
regards
gem
Jaime Valencia Mon, 10/27/2008 - 22:53
  • Cisco Employee,
  • Hall of Fame,
    2011
on Exchange Admin you can check the mailstores and the status of each one
java
tim.giles Tue, 10/28/2008 - 01:11
  • Silver, 250 points or more
Gem,
Ok, here a step-by-step guide on how to check:
1) Go into START > Programs > Microsoft Exchange > System Manager
2) Expand the tree as follows, Administrative Groups > First Administrative Group > Servers
3) Expand the server which Unity is integrated with
4) Open up the First Storage Group and you will see all the mailstores. Check they are all mounted.
You can check all the Exchange servers and stores quickly if you're not sure. More information can be found here:
http://technet.microsoft.com/en-us/library/aa995829(EXCHG.65).aspx
You might also want to check whether the Exchange server is actually up and running (have you tried pinging it from Unity)?
