Config WLAN override in CLI
Answered Question
Oct 27th, 2008
I currently have case open with TAC where my LWAPs are losing their override settings . The workaround that I was given is to manually adding SSIDs to the override settings via the GUI. The GUI sucks for this. Can't do text search and you can't sort the columns.
Is there a command to add SSID to the override settings in CLI?
Correct Answer by Rob Huffman about 8 years 8 months ago
Hi Wilfred,
Using the CLI to Enable WLAN Override
To enable the WLAN Override option using the controller CLI, enter this command:
config ap wlan enable {802.11a | 802.11b} cisco_ap
To define which WLANs you wish to transmit, enter this command:
config ap wlan add {802.11a | 802.11b} wlan-id cisco_ap
From this good doc;
http://www.cisco.com/en/US/docs/wireless/controller/4.0/configuration/guide/c40wlan.html#wp1114777
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Tue, 10/28/2008 - 07:25
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Wilfred,
From this good doc;
Hope this helps!
Rob
mwilson706 Tue, 11/18/2008 - 12:58
Also, verify the templates that are being pushed out have the correct wlan override settings if multiple people manage the WCS.
Trending Topics - Security & Network
