VPN client behind router 851 t o ASA5520
Oct 27th, 2008
I have a VPN client behind a router 851 connect to an ADSL line. The VPN client version 5.0.04.0300 connect to an ASA5520 at the main office. Connection successful, but it take 60 seconds to get an access to the remote network. I swap the router 851 for a cheap linksys WRT54G with Ipsec pass-through and the network access is up 1 second after the connection. What's happening with the router 851 ?
Thanks.
luc_despatie@uq... Tue, 10/28/2008 - 05:51
The VPN connection is between a Windows XP client to an ASA5520. But the XP client is behind a router 851, it connect, but after you have to wait 60 seconds to gain access to the network. I try two others sites with ADSL line, no router 851, and the network access is possible just after the client connect. Hope it is more clear. Strange behavior.
