Tool used for monitoring Voice Gateways
Oct 27th, 2008
I would like to know which tools that are available to do realtime monitoring for cisco VoiceGateways AS5400.
We would like to monitor trunk utilization/ number of active calls ...
We need a real time monitoring capabilities.
Thanks for the advise.
virverma Thu, 01/29/2009 - 18:46
you can start from here:
goto MIB Locator, select the IOS version, then platform family, it will
narrow down to a small number of MIB to choose from.
and search for " number of calls" and check the box of " Include object
descriptions in search"
about 21 MIB objects are related. Each one can check the supported
version of IOS.
Nicholas Matthews Thu, 01/29/2009 - 20:28
'show isdn call-rate' is pretty awesome for this.
Otherwise you can look towards RADIUS solutions, or the previous post.
