WPA2 on 1200 Series?
Oct 27th, 2008
  • Purple, 4500 points or more
I have WPA configured on my APs, but I'm interested in going to WPA2. What do I need to change under the SSID? I don't use the web interface, so CLI commands would be best.
Thanks!
John
jeff.kish Mon, 10/27/2008 - 13:19
  • Silver, 250 points or more
What model of access point are you using? Is it truly a 1200, or is it a 1231 or 1242? WPA2 is not supported in some earlier models.
Under your ssid, issue the command "authentication key-management wpa2-psk". Under the Dot11Radio, enter the command "encryption mode ciphers aes". That should do it, as long as your AP supports it!
dennischolmes Tue, 10/28/2008 - 06:31
  • Gold, 750 points or more
WPA2 is only supported on APs that have the 802.11g radio modules installed. This is because the older radios do not support AES encryption. You can upgrade almost all of the 1200 series APs with a module upgrade if necessary.
John Blakley Tue, 10/28/2008 - 06:44
They're 1231Gs. How would I enable it under the cli?
jeff.kish Wed, 10/29/2008 - 06:48
config t
ssid [ssid name]
authentication open
authentication key-management wpa [version 2]
wpa-psk ascii [password]
interface Dot11Radio
ssid [ssid name]
NOTE: My previous syntax was wrong, I believe. I'm going on memory here, so hopefully this is correct. Please post if this doesn't work.
Also, the "version 2" is not supported by all IOS versions, so it may or may not be available.
John Blakley Wed, 10/29/2008 - 06:57
Thank you for the response Jeff. I don't have that option under the ssid. I only have cckm or wpa, and no option to set the version.
I do have encryption mode ciphers aes-ccm under the radio interface. I'll play around with these and let you know what happens. I'm just going to change the ciphers from tkip to aes-ccm and see what happens.
--John
dennischolmes Wed, 10/29/2008 - 07:16
Why don't you upgrade the code on the AP?
John Blakley Wed, 10/29/2008 - 07:20
I just updated it yesterday. It's at 12.3.8-JEB1.
scottmac Tue, 01/06/2009 - 10:07
  • Green, 3000 points or more
WPA2 is only supported on later hardware versions of the 802.11g radios.
I believe it's the xxx-21g ... something like that is the earliest hardware that supports WPA2
I couldn't find the old docs and I ran out of time to search. Try a search on "WPA2" in the main site.
Good Luck
Scott
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
