Unity 5.0 with Exchange 2008?
Oct 27th, 2008
Anyone using this set up yet?
If so, any problems or issues?
ranpierce Mon, 10/27/2008 - 14:51
Only suppoted up to E2k7.
I do not think there is a E2k8 yet. Do you mean Win2k8? If there is then it is not supported yet.
Many people are still having issues with E2k7.
ranpierce Tue, 10/28/2008 - 08:38
I know E2k7 and Wink8 are supported but I do not have a doc on hand.
You are correct that there was a bug with MWI but it is fixed with E2k7 sp1 rollup 4.
I will try to find a doc for you.
ranpierce Tue, 10/28/2008 - 08:41
what I was saying is the the is not exhange 2008 to my knowlege.
Tray Stoutmeyer Tue, 10/28/2008 - 08:46
Just re-read the original post. I mis-understood. Sorry about that. I thought you were saying Win2k8 wasn't supported. My bad. =)
